The bottom of the left wing was blocked using 220grit to a virtually flawless contour then top cut with 320 before flipping the wing over to tackle the topside. The topside had already been blocked with 180 grit months ago when I rolled on the white, but she needed a fresh round of blocking to prep for final primer. I also tackled the wingroot section with wet micro where obvious low spots had developed. Tomorrow I should be able to block this down and have her ready for primer tomorrow.
