Building Integrity
Date:  7-25-2018
Number of Hours:  0.00
Manual Reference:  Section 2
Brief Description:  The HACK is a winner!
THE ECU HACK IS A WINNER! Check out the awesome results of modding the air temp sensor. The Hack was a success in multiple categories. So here they are in data form. I'll let the numbers do the talking :)
Cruise fuel burn: Stock setting: 10.2gph / Lean mod: 9.5gph
WOT fuel burn: Stock setting: 11.5gph / Lean mod: 11gph
Not only is there better fuel efficiency, but I also saw an additional 10rpm, and 2kts in speed all while burning 5-7% LESS fuel. She runs smoother and the pipes are no longer "black" but now a more "tan" color where they should be! The difference in CHT's is only about 3 deg.F warmer.
This $20 mod now gives me an addition 100 miles of range and around $13 of fuel savings on every tank. Now I just need to find a way to install it in the airplane permanently.
WIN> WIN> WIN.
Cruise Stock
Cruise Stock
Cruise Lean
Cruise Lean
