Brief Description: Cowls get more micro, of course they do
Back on the micro train...story of this build. Today, the Upper cowl leading edge lip was sanded to a nice contour. Then taped off and re-installed. This then allows me to lay up micro on top of the intake scoop to match the leading edge of the cowling. After cure, the scoop will be sanded to match the cowling. The lower cowl also needed more micro spot filler after yesterdays Z-Grip treatment. This may put her into the final primer category. We shall see.
