Building Integrity
Date:  12-13-2017
Manual Reference:  ch 25
Brief Description:  Both Cowls get filler
The lower cowling needed more Filler to match the contour of the left side of the scoop but is getting very close to final primer. Take a look at the nose. Filler primer filled the scratches and final low spots, was wet sanded with a sanding sponge and is now ready for final primer. This will come later on after the bottom is primed white and ready for paint.
After trimming the upper cowling for a nice leading edge transition, I piled on the micro. The micro will determine the thickness of the cowling and then will be taped off and the turtle deck and scoop will get micro to match. A nice tight fit is coming soon...
Micro build up
Micro build up
Z-Grip the low spot
Z-Grip the low spot
Ready for final primer
