The induction box went together as easy as a model. it will contain an access hole for the filter's band clamp and still needs a drain with SS mesh much like the fuel system. Then 1 ply BID and radiused corners for smooth airflow. Boy will this setup be tight. I may not be able to run a silicone coupler like before and will have to resort to the CAT tubing. Keeping the bends to a minimum will be crucial.
