Building Integrity
Date:  9-19-2016
Number of Hours:  0.50
Manual Reference:  Section 2
Brief Description:  New Cooler fittings are in
This oil cooler is literally the 4th oil cooler I will have tried on this bird. This one however, is an 8 row dual pass cooler that will most def. help the temps at least a little if not more. The lower fitting will require me to cut out the lower cowling to clear the line and fitting, but it won't be a big deal and certainly won't take away from the aerodynamics of the airplane. Now where did I put my dremel? :)
Dual pass cooler
Dual pass cooler
