The 2 oil coolers were fit together while precisely mounting the steel fittings to provide clearance for the new -8 oil lines that will be installed. I then laid up 3 plies BID on the new cooler attached to the original inner baffle to create a seal all around on both coolers. Tomorrow the baffle should easily be finished and painted while waiting for the new -8 line to arrive.
