Building Integrity
Date:  3-22-2016
Number of Hours:  1.00
Manual Reference:  ch 21
Brief Description:  Fuel still flows
Look at the picture attached. there are 2 spots that are lighter than the surrounding brown areas. These were nothing other than pockets full of 100LL. HOW THE HECK IS FUEL DRAINING INTO THIS LAYUP! THE TANKS ARE DRY! My only guess is that this is from fuel that had been inside the walls of the fuselage that needed to evap or drain. No way it came from the sump. I removed the peel ply, drained the pockets, and filled them with flox and BID. I put a small amount of heat on it and came back later to see it cured just fine. Tomorrow I'll flood the tank with fuel and see what turns up. my...gosh...
more fuel
more fuel
