- I installed the right aileron bellcrank after sliming the bushing with aeroshell 22 grease like the left side. It needed some more smoothing - so I handled up on that too.
- I also played around with the fit of the outer wing skin over the inner wing skin and made sure it was flush to the trailing portion of the leading edge.
- Since the primer was now dried, I installed the snap bushings and ran the Pitot / AoA tubing thru the left wings. Noticed that the red tubing is touching the aileron bellcrank. Will address that after I get back from the engine build
- I tape sealed the outer ends and then covered the wings with a plastic drop cloth
