Brief Description: (cont.) Tie down-assembly - left spar
The method for drilling the tie-down assembly is to dirll the match hole to the specified dimensions on the tie-down assembly, then bolt the tied-down assembly to the spar and back drill the remaining needed holes. It worked out pretty good... I got the left tie-down completely drilled and the two spacers main holes are drilled. Hopefully tomorrow I can get the right spar tie-down done.
