Jims RV-8
Date:  1-7-2024
Number of Hours:  1.80
Brief Description:  Trim motor relay wiring
Today, I continued the wiring of the other four relays as I await the shipping of the newly purchased relays. The setup is the same, so I can pull wires while waiting for the delivery. The spar pass-thru is getting full of wires, and it took me a long time and a few different tries to get the four wires through finally. I still have a few more that need to go through the spar area, so I put a pink string to pull them through. Initially, I tried the stainless wire as a pull-thru, but it was getting a little too crowded as it had a small hook to hold the wire, which was getting caught on the snap bushing and wires.
Finished ends at the relay farm
Unfinished ends at the pilot stick
