Jims RV-8
Date:  3-26-2023
Number of Hours:  1.70
Brief Description:  Connector - Indicator lights
While doing the avionics box fitting, I also considered the remaining items on the "wiring" to-do list. One of those items is the terminations for the three incandescent bulbs (Smoke Pump On, Low Volts-Alternator 1, and Low Volts-Alternator 2). Initially, I was going to use twelve knife splices to attach these wires, and when a bulb burned out, I could undo the knife splices and replace the bulb. Since I will still need to soldier the new bulb anyway, I decided to use the 6-pin AeroLED connector I have in stock and make it one connection for all twelve wires. I drew the pinout diagram, labeled the wires temporarily with tape, and crimped the pins on the bulb side.
bulb side wires marked
panel side wires marked
bulb side pins crimped on
