Jims RV-8
Date:  8-27-2022
Number of Hours:  1.20
Brief Description:  Nav/Strobe ground
Back on the Nav/Strobe wiring - I first threaded the black 18 gauge wire around and over to the FOT, labeled it, crimped on the terminal, and installed it on the FOT. Then it was back to figuring out how to connect these three sets of Nav/Strobe wires and ground the shielding. The first idea was to use one big solder sleeve and tie them all together, but they didn't fit. Another idea was to daisy chain them and then finally run them into a single ground, which is what I decided to do.
