Tonight I worked on stripping/prepping the three nav/strobe wires for the wires ready for the terminals at the switches. I first went to about 4 inches but decided I had plenty of wire and should strip off and prep a few more inches, so I ended up at 6 inches. I also did some drilling and snap bushing work in the fuse and thought about the grounds. I have nine remaining grounds on my FOT, and if I run a separate ground for each of the three wires - well, I will have only six remaining. See what I did there? :) So I am deciding if I want to run them separately or together. I did some research, but no clear push in any particular direction - either way is acceptable.
