Jims RV-8
Date: 5-20-2022
Number of Hours: 2.00
Brief Description: More labels
I made another change to the labels ... well, actually, I forgot to re-purpose the "E-Bus" circuit breaker on the panel bank to something else when I did the re-design on the E-Bus. I ran the switch thru the 30A relay from the fused power to be able to use more amps on the extra bus. When I realized that I had a CB labeled "E-bus" that I wasn't going to use, I decided that now was the time to change the label, get a 2A CB, switch it out, and put my magnetometer in that hole. So, back to the label making. While I was working up my labels, I happened to be perusing a guy named Phillip from down in the Houston area and saw where he was doing the dry transfer labels on his stick. I thought it was a great idea, so I started working on the labels for my stick. Since I wasn't going to use too much space, I let Rob and Bob know what I was doing and asked if they wanted to label their sticks. They both have used the same dry transfer labels, so they are familiar with the process, they sent me their labels, and I added them to my order, and off we go.
Here is the top of the stick
side buttons - not sure if A/P disc is going there or on the back side
