Brief Description: Main Avionics Wiring Harness #2
Here are some more pictures. I was able to close the avionics access door, but it's not workable as is. There is also a picture of the lacing that was removed to get enough slack in the 507 connection. I will re-lace as appropriate and tidy things up. I have some other areas that I need to cut away for wire access, like the post that the backup battery goes around and a slight relief for the transponder wires - little things like that.
