Jims RV-8
Date:  3-3-2022
Number of Hours:  0.00
Brief Description:  Panel Labels - revisions #2
For a more detailed view: I removed circuit breakers to get a flat surface to work, then taped off everything I wanted to keep, exposing the GMC507 label. I scrapped it off with a flat scrap piece of wood and then cleaned the surface with rubbing alcohol. Then I removed the tape to line up the new label with the other labels and applied it.
isolate the label to be removed
remove label
remove label
line up new label and burnish on
