I got the old labels removed and the new ones installed. I like this medium; these labels aren't easy to remove, which is a good thing, but they are removable. After cleaning up the surface, I put the new labels on.
I always knew I would know what the switch is just by memorization and feeling, but I wanted to flip the lettering on top of the switch anyway. The new labels will be easier to read, and the only thing on the bottom of the switch is the "OFF." I also switched out the 1-3 switch in the left center for a 2-10 (DPDT) switch as that will be my OFF/SYNC/WIG-WAG switch where I can sync the lights or allow them to flash out of sync. Might be handy.
I also removed the circuit breakers and flipped the GMC507 and G5 labels to get the G5 off the backup bus as it has a backup battery—more detail on that on the next page.
before
lining everything up - see backlight on right two holes
