Jims RV-8
Date:  10-19-2021
Number of Hours:  2.30
Brief Description:  Bus Wiring #4 - Bus connections
Before and after Greg was here, I was working on terminating the bus wiring and wiring up the connection from the contactor to the diode. I played around with the best way for the wires to connect to the buses given that the buses are mounted on a movable, hinged panel. Turns out just angling them in is best. When the panel is closed (99.9% of the time) they sit off the panel and the bus, and they just kind of lay down when the panel is open, so for now, this is good. There will be many more wires running along this track, but I won't likely tie them into these bus wires.
Diode partially wired
Buses wired, and labeled
