Following Bob's lead, I decided I would also make a doubler for the VOR/LOC/GS antenna as I have chosen to mount my antenna at the rear, underside of the fuselage. Using some scrap 1/32" sheet I cut out a piece and marked it for bends and rivet holes, following the directions Bob provided. Then I climbed under the fuse and match drilled and clecoed the doubler. Then everything was taken off and I deburred all the holes on the fuse and the doubler. I made the strengthening bends in the doubler and then did a test fit of the doubler on the inside of the fuse. Looks good!
