Jims RV-8
Date:  10-27-2020
Brief Description:  Panel Plan #15
Added in the 3 annunciator lights in the left top center panel. They will tell me when I have low voltage in the main or secondary alternator output (red light) or when I have the smoke pump on (green light). There will be another annunciator light on the right side panel which will tell me if the starter is stuck (red light). I also have the markups for the two rheostats in the lower left center panel. I took some time for some discussions with Bob about the panel cutting logistics and what his preferences are going forward.
At this point, the center panel is complete, and I have the side panels laid out, but not marked - I will need to put in two more CB's on the right side - and then mark all dimensions, that should be the last of it before sending it all off to Bob for cutting.
added the annunciator lights and rheo
finished look...almost
