I worked out the wiring plan (using the 2-10 switch) for the front and rear baggage compartments. Even though I am using the 700-10-2 switch to go from OFF – FRONT – REAR, it is a different wiring diagram than the glare shield and front cockpit lights because there will be no rheostat on the baggage lights. Both the baggage areas will get full power with no need to dim. Of course, then I started thinking about other switch wiring options using the 10-2, such as OFF – FRONT – BOTH. This would be good for times when Teresa and I are both loading luggage – both get light. Otherwise, it’s a either off, front on only or rear on only. Hmmm...what option would be best? Decisions, decisions…
