Brief Description: Finished front seat heat wiring
I have been stewing over how to get the pos/neg wires from the aircraft power / ground to the front seat heater connections with the curves, wing spar bolts, fiberglass console and cover. There are lots of places that will damage wires, so I decided to run them thru some surplus 3/16" brake line that I bought for just such a purpose. I also needed to do some final fit work on the fiberglass console and make room for the tube in the corner with some trimming.
