Needing to finish up the canopy skirt will require some more sanding of the filler on the skirt and then finishing the aft canopy skirt glass. So, before I introduce all that dust back into the shop environment, I wanted to strip off the original wrap, get the canopy cleaned up and then re-covered the exterior with tape. The original wrap is pretty thin, is really only meant to be temporary and has served me well. But it has seen better days and it is time to replace it. It took a few iterations of removing the canopy from the fuse - cleaning it up inside and out and then reinstalling it before I had all pristine. Man, that's a beautiful canopy if I do say so myself. I hate to cover it up - it looks so good! Major visual inspiration!
