Brief Description: more console and flange sanding
More of the sameā¦ sanding the storage box and removing slurry as well as cutting and sanding the flange. I have the flange narrowed down about as close as I possible until I bond it to the storage box. Then I will cut/smooth it back to the bond area.
I also need to thin the corners as they are thicker due to more layers of glass.
