Jims RV-8
Date:  3-27-2018
Number of Hours:  1.00
Brief Description:  more console and flange sanding
More of the sameā€¦ sanding the storage box and removing slurry as well as cutting and sanding the flange. I have the flange narrowed down about as close as I possible until I bond it to the storage box. Then I will cut/smooth it back to the bond area.
I also need to thin the corners as they are thicker due to more layers of glass.
flange and box
flange and box
dremel tool with grinder
cutoff wheel for straight flange cuts
