Tonight things went much smoother because I had an approach, a method. I sanded off the high spots and the heavy areas and generally smoothed it. Lots of over done areas as I expected. Then, I precut all of the glass which allowed me to take more time to place and wet the fabric. I was able to take my time and use much less resin...which is how you are supposed to do it. I didn't feel comfortable placing the last sheet, the right side glass, so I will get that one next time. There should be much less sanding to do after this session compared to the last session.
