Back to brake work - I was able to get the F-8105 flexible brake lines installed as well as the lines running from the bulkhead down to the landing gear. Since I have the one-piece Grove gear the brake fittings sit on top of the gear. That fitting is not a standard Van's part so I will have to order that one before progressing and installing the fitting-to-tubing. I would also like to study up on the proper method of installing the rubber brake lines that run to the from the brake reservoir to the bulkhead and then to the rudder pedals.
