Jims RV-8
Date:  12-18-2017
Brief Description:  Wingtip Lighting – Left wingtip
Started from scratch on the left wingtip and cut the hole, sanded it out with the dremel and the circular sanding pad, then sanded with the sandpaper and started the tedious process of making the fit much better. I have the left side cutout up to the same point as the right wingtip.
