The rudder also needs limits set, but those are done by external stops being adjusted. The limit on the rudder is to be no closer to the neutral elevators than 1". So I was targeting mine at 1 and 1/4" inch. After getting the vertical stabilizer and rudder installed, I got the left set at 1 1/4" and the right set at 1 5/16" so I am good with that.
I will need to prime these parts - at least the metal facing sides so I am done for the day.
