After test fitting the gear in it's approximate position it became clear that the F-802-K's would have to be notched to allow the U-803 Outboard Main Gear Attach Bracket to seat at the proper angle...so, I drew some preliminary marks on the F802-K's and got to work with the dremel tool. Cutting was the easy part - took about 5 minutes. The measuring and set up took probably 15 minutes and the other 40 was all of the radiusing, smoothing, filing and scotchbriting.
