I doinked around in the garage a bit today and managed to get the fuel gauges cut and the side cover measured drawn and cut. I will bend it and drill it for rivets next time. I still need to finish cut the aft attach tab (under the fuel gauge face plate). I will probably cut it back so that it doesn't slide under the face plate so I can remove the fuel gauge ramp independently from the fuel selector.
