Brief Description: Fuse Final Assembly - Outboard seat ribs
Installed the F-806E Spacer and Bolt at each F-815 outboard seat rib (torqued to 24 in./lbs.) and then riveted the fwd outboard (F-815A), and aft outboard seat ribs (F-815B) to the F-806B-1 Rear Spar Attach Bulkhead.
