Brief Description: Mid Fuse Structure - Combining with Center Section
I joined the Seat Rib Subassembly with the Center section, clecoing the bottom flanges of the center section to the bottom skins - as well as the seat ramp supports (F-814E-L/R-1). I drilled the 1/8" rivet holes that joint the seat ramp supports to the inner seat ribs.
Next, I used the fly cutter and made the rear seat ventilation hole in the right outside rib (F-815A-R-1) and right side mid skin (F-823-1) and then deburred the holes and then clecoed the outboaed ribs (for and aft) to the seat rib subassembly - and then clecoed the mid side skins in place.
Then I clecoed all of the left and right arm rests and bulkheads in place - see next log for these pictures as I ran out of room. :)
