Since I couldn't get any more rivets pulled on the leading edge, and since I had some shop time left, I moved on to the flaps. I deburred/edged the spars, smotthed the lightening holes, clecoed the ribs to the spars and clecoed the bottom skin to the spar/ribs. Then drilled the ribs to the skin as that was all that was depicted in the plans at this point. I also made the FL-708 spacers that go on the inside/outside ribs of both flaps. That's all for today.
