Brief Description: Tank plumbing fittings – left tank
The Van’s order came in the mail so I had my tank fittings for the left tank vent tube. I cleaned all the parts up good with MEK, cleaned up the inside of the tank a bit, prosealed up the fittings, and attached the nut, tightened it down and slathered the whole fitting in proseal. I also applied proseal to the back (interior) side of the baffle, on the platenuts and rivets, sealing everything that might provide a path for fuel from the inside of the tank to the outside.
