Brief Description: CS and installing more platenuts
This morning I finished countersinking the rest of the main screw holes on the left spar. I also installed the access platenuts on the spars. There are 3 access plates on the bottom of each wing, with 4 platenuts each installed on the spars, with the rest of the platenuts for the access panels being installed on the wing skins.
The below picture shows one set of the access panel platenuts on the bottom (4 smaller platenuts), the bottom spar platenuts (larger ones) and the upper flange showing the finished counter sinks.
The kid is coming home from his freshman year of college today...so I am off the clock for a while! Yippeee!
