RV-6A - GBC
Date:  6-15-2014
Number of Hours:  2.50
Brief Description:  Cowl - both, contours
Went aggressive on some additional fiberglass/resin on a few deficiencies; 1) Rt 'cheek' was mis-matched top to bottom, 2) Rt side of cowl bottom ring 1/8" shy of alignment with top ring, and 3) edge of inlet was missing 3/4" on outboard side of bottom (and small portion of top).
Added material, filed with rasp and coarse files. Rough sanded to contour For inlet, layed up a 6" section of glass cloth, saturated, and used a 0.025" AL scrap to clamp a mold on inlet. Rough trimmed with shears, filed with rasp. During assembly fit found that the outboard top has a small deficiency, too. Will have to evaluate how this aligns with top of inlet and rubberized 'fence'.
Added to outer cheek
Added to Rt side ring
Added edge to Lt inlet
