Aligned, clamped and removed the canopy frame. Riveted the forward frame with the splice plate. Then finished all the little deburring, scuffing, and clean-up for a good coat of primer. Also prepped and primed the splice plates for the frame side rails.
Began the process of fitting the canopy frame reinforcement kit. Reviewed instructions and procedures. Preliminary fitting shows that a few mods will be needed to fit the kit.
