Fought my way through removing and replacing the SV-NET harness that was installed to the ADAHRS in the aft compartment, (mistakenly installed with "servo wiring" instead of SV-NET standard).
New 15 ft harness uses all 9 wires while the servo harness uses only 7 wires, and 3 of those are NOT in the D9 connector. This new harness was wrapped the entire length, and connectorized on one end, with pins only installed on the other. Easy to install (in theory) but removing the wires were easy, installing the new harness into the conduit was a PITA. Even using a pull-string the conduit was very full and tight. Had to remove the antenna coax, and ELT panel wire.
