Pulled out some of the harnesses from the conduit and drilled a 7/8" hole under the deck on the Rt side longeron. Re-pulled the harnesses thru that hole and then routed additional harnesses into the conduit. Found enough SV-Network wire length to run the last harness to the aft compartment for the SV-ADAHRS.
Unfortunately, committed the electricians proverbial OOPS, routing OVER the seat pan rib instead of under (will fix it tomorrow).
Adjusted destination ends, tie-wrapped some and cleaned-up to review.
