Added 4 pass-thru openings in the subpanel to facilitate the wiring harness routing. With the tip-up canopy, everything should be detachable from the panel to service or modify in the future. This requires predomniantly all wiring be attached to the subpanel.
Used the fly-cutter in a variable speed handheld drill to cut 3 of the holes and then deburred.
