Brief Description: Studied the components and harnesses
Studied the Dynon SkyView installation manual v6-0 (just released) and all the components, harnesses, and interfaces. Determined where to place two SV-NET hubs (5 connector DB-9M), and confirmed need to fabricate two brackets and proper gender for the AP servo wiring. Each have pig-tails with male pins for DB-9, so a connector & bracket complete the servo prep.
The display panel SV-1000 will have two DB-9M connectors, as does the newly released SV-COMM radio control panel. This configuration makes the SV network wiring possible with two SV-net hubs. Other components will have serial connectors to the SV-1000 DB-37 connector.
Starting to make sense, and need to work step by step on a mock up for harnesses.
