Removed both elevators and cleaed-up the Heim bearings, Removed pin from elevator trim tab and replaced with a new pin with retention hook and hole for safetie (need to safety)
Added the new clevis but the pin is too small for the clevis hole, will require a revision to the trim tab horn.
Added correct fasteners for the horns, elevator pivots and elevator main pivot.
