RV-6A - GBC
Date:  5-20-2006
Brief Description:  Transported small components
Being in the midst of a home remodel project can allow one to take advantage of tactical cover. Strategically placing airplane components amongst the 5,000 pounds of travertine and boxes of drywall mud may appear on the surface to be a good way to camouflage the home invasion by a Van's RV kit, however, failing to include the cover of darkness renders the plan significantly less stealthy.
Recommendation: If you DON'T have spousal support for the airplane factory NOW, you should start the 12-step program for redemption soon after taking these types of pictures.
Step #1 - yes sweetie pie, it IS going to the garage today ...
Step #2 - actually move it TODAY.
Step #3 - no direct eye contact, and maintain a posture of submission for the rest of the week, at least.
I don't want to disclose all the steps and put any therapists out of work. It can get dicey, too.
Flap assembly
Flap assembly
Airplane? where?
Airplane? where?
Ailerons & HS
Ailerons & HS
