Ordered and received the WD-655 FPKIT (Finger Patch Kit - rudder pedals) re: SB 99-06-1.
Reviewed with a welding shop that works with roll cage construction and 4130 steel. Installation of the patch kit will avoid the need for periodic inspections.
Upon completion will have all the 4130 steel control components bead blasted and powder coated. Should be ready by the time the garage doors are installed.
