Removed the panel again, and riveted the 'canopy side decks' to the longerons & subpanel. Should have done this long ago, but delayed each time to work on 'other tasks'.
Removed the canopy to have access for the rivet gun. Bucking bar is tight on the underside.
Got an ANL fuse holder and 60A fuse, for the Plane-Power alternator power circuit. Need to add doubler and nutplates to FW.
