Tail light mount, fabricated a 1/8" mounting plate and blind riveted to the bottom rudder fairing.
Added micro resin to the outboard portions of the canopy fairing and rough sanded to determine contour, then added another layer in those areas.
Follow-up on the starter wiring and testing ... found a specification note in the SkyTec data that indicated where I had incorrectly connected the lug (used only in Robinson helocopter applications). Starter now functioning well.
