Touched up the GB988 rattlecan primer, finalized a few holes that lacked C/S, and deburred a few edges. Shot a little Rustoleum on the components because this will be riveted shut and inaccessible.
Clecoed on the three tip-up stiffeners to rivet the first round of universal rivets on the frame edge. Sequence of assembly dictated by diminishing access to buck the shop side.
Also worked on the tip-up skin 'curve' to avoid putting any tension on the finished canopy. Bend of skin is now relaxed against the frame everywhere.
