RV-6A - GBC
Date:  5-24-2013
Number of Hours:  3.50
Brief Description:  Rollbar - Brackets
Worked on further fabrication of the rollbar bracket for the rt side. Carefull matching of the components to ensure that the new rollbar aligns with the rear window (which was already drilled and countersunk).
After comparison to the old brackets, the two angles were riveted together for ease of positioning.
The rollbar is still very flexible with only 30% clecoed, so it is not perfectly flat/straight. As rivets are added it will be necessary to firmly secure it flat and not allow any twist.
At this point the fit is very satisfactory.
New bracket - fitting
Testing alignment - prelim
Alignment compared to existing holes
